Kickdown DSG
hobbel de bobbel
  • Reacties 80
  • Aangemaakt
  • Laatste reactie
Beste reacties in dit topic
Trouwens als je gaat zoeken naar de herkomst van 'gaspedaal'. Dat schijnt een groot raadsel te zijn.
Hoewel je in het duits ook zegt "Gib Gas!"
Meest in de buurt komt nog de verklaring van dat je met het versnellingspedaal de hoeveelheid brandbaar gasmengsel in de cylinders uiteindelijk regelt (maar dat gaat niet op voor b.v. een Tesla)
BTW: Ed; vliegtuigen sturen ook hoor...ook op de grond...
Even weer terug naar de les heren, hoewel ik overigens een warm voorstander ben van off/topic uitstapjes :)
So on the way home from work today (usually ~14km) I took the 55km route! lol
I spent a decent amount of time playing around with the throttle in the various DSG modes.
I've been becoming familiar with the D mode, with it's many "moods", to the amount of throttle that you can apply before you kick down a gear or two.
What I like about the M mode is that it doesn't matter HOW QUICKLY you push the pedal to 100% throttle, as long as you don't go past the resistance point at the 100% throttle position, you won't hit the physical kick down switch. It makes me wonder, in all the complaints about the DSG and how you can't accelerate without it kicking down and all that, whether most people actually know that there is a physical kick down switch BEYOND the position of 100% / WOT. Anyway - it makes it quite enjoyable once you realise where 100% is and find that resistance position, as you can then do torquey 80 to 100 acceleration in 5th, rather than powery 80 to 100 acceleration in 3rd which automatically occurs if you hit the kickdown button.
Also, after comments that Dave_R made a while back, I tried S mode whilst the cruise control was active. Doing 80km/h along a major 80km/h road, it was extremely amusing how THE MOMENT you touch the accelerator it drops a gear immediately. But that's just from the lightest of touches. Any more than a light touch and it drops two or three, depending on how far you push the accelerator... awesome
WOT= Way of travel dwz. de physieke mate van intrappen ( sorry, induwen) van het acceleratiepedaal ( we leren allemaal)
Hrt meest interessant van deze observatie vind ik, dat er bij de DSG automaat kennelijk 2 manieren van snel accellereren zijn:
de maximale koppelmethode, 100 % WOT
de maximale vermogensmethode met de physieke kickdownschakelaar (110 % WOT) ingeschakeld.
(ik ga nog wel even met een spiegeltje onder mijn vermogens pedaal kijken, wat zich daar allemaal afspeelt, sommigen brengen daar een kunstofblokje met nauwkeurig gespecificeerde afmetingen aan om de schakelaar, op een goedkope, begrijpelijke manier, uit te schakelen)
Tjonge, verrassend. In de manual staat hier dacht ik niets over. Zal het straks eens uitproberen (wel slecht voor het verbruik natuurlijk). Zou dus eigenlijk een kickdown + zijn
Maar ik denk eigenlijk dat ik dit wel vaker heb ingeschakeld en voor mij dus kd is. We zullen zien, ik zal beide methoden uitproberen
Dat het tegenwoordig een simpele potmeter is kan ik wel beamen, met VCDS kan je op de % nauwkeurig de stand van je gaspedaal zien. Bovendien is je gaspedaal dynamisch, dat wil zeggen dat de auto (gaspedaal) wat inhoudt als hij koud is en wellicht zelfs tussen versnellingen anders kan reageren.
En Hobbel heeft gelijk tot mijn stomme verbazing. Dacht dat ik de kick down kende, maar Henk heeft idd een geheim knopje.
Op A6 en prov. weg een aantal keren uitgeprobeerd; gewoon intrappen tot de bodem leidt tot terugschakelen en doortrekken tot rond de 4000 rpm (als je vanaf 50 km per uur doet trekt hij nog wat langer door). Echter als je op de bodem zit en je trapt door, dan voel je idd duidelijk de klik van het "knopje" en trekt hij door richting de 6000 rpm. Amazing!
Ik snapte eigenlijk al niet goed hoe je 'm boven de 4000 moest krijgen. Kan dus bijna alleen met dat maffe knopje.
Maar sneller optrekken doet hij dan denk ik nog steeds niet. Het koppel neemt niet meer toe. En of de extra pk's dan wat doen, ik weet het niet.
aangepast door CaseyBasey
Het gaat er ook echt niet zuiniger/sneller op worden als je lang in een lagere versnelling/hogere toeren blijft, maar het is juist bij het rijden in de meest zuinige stand effectief. 100 km/u in zijn 6 en je wilt even snel naar de 120, dan gaat dit waarschijnlijk sneller met kickdown in zijn 5 (of 4) dan gewoon in zijn 6. Hangt natuurlijk af van de kracht van de motor e.d. maar het gaat om die kleine snelle sprintjes als het ware, niet om constant in te rijden...
Zoiets als een inhaalmanoeuvre, als ik met 75 (5e versnelling, cc) achter een trage slak geplakt zit en snel wil inhalen op de N-weg, dan gaat hij echt naar zijn 4 hoor :)
