Nicolae Samareanu
Nicolae Samareanu's prestaties
  1. Hello, I'm having trouble understanding some fault codes, they don't come up as recent but id like to know what they are all about. My car is an Octavia 2 1z 1.4 MPI Cheers! 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: OK 0000 Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb Part No SW: 3T0 820 047 AB HW: 3T0 820 047 AB Component: AC Manuell H19 0608 1 Fault Found: 13701936 - Function Restriction due to Faults in Other Modules U1113 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 254 Reset counter: 148 Mileage: 42747 km Date: 2014.12.08 Time: 11:54:22 Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb Part No SW: 1K0 937 086 N HW: 1K0 937 086 N Component: BCM PQ35 M+ 110 0651 Subsystem 1 - Part No: 1Z1 955 119 D Labels: 1KX-955-119.CLB Component: Wischer 30071 26 0601 Coding: 00D7B7 Subsystem 2 - Part No: 5J0 951 172 Component: DWA-Sensor 03 03 1209 Subsystem 3 - Part No: 1K8 951 605 B Component: LIN BACKUP HO H11 9005 2 Faults Found: 02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20) 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 5 Fault Frequency: 1 Reset counter: 114 Mileage: 42747 km Time Indication: 0 Date: 2014.12.08 Time: 11:34:39 Freeze Frame: Term 15 On Voltage: 12.75 V ON ON Term 50 Off OFF OFF 02395 - Parking Light Front Right (M3) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 2 Fault Frequency: 7 Reset counter: 148 Mileage: 60232 km Time Indication: 0 Date: 2016.08.15 Time: 18:53:38 Freeze Frame: Term 15 On Voltage: 12.50 V ON ON Term 50 Off OFF OFF
